adding2n2is5
I have noticed that since the update to android 2.1 that battery drain is crazy during times that it shouldn't be. After some experimenting and searching through phone settings I found that the phone will tell you what had been using the battery since it was last unplugged. I found that it shows the map app using over 90% of batt even when the program had never been opened. I had also verified through ATK that map app wasn't even open. Anyone else setting this? ANY ideas on what to do?
