Help maps and locations updates
chippy30
Member
my desire hd is on o2 network and everytime i use the maps or locations it asks me to update them, when i do it takes for ever to update even when using a wi fi conection from my internet at home, why is this, and when they have updated the next couple of times i use them they are ok, then it will ask for a update again,
I have a similar problem with apps that are set to auto update. They sit there supposedly downloading but never seem to make any progress. I long press on them and tap 'Cancel Download' and then update them manually which seems to do the trick. Not sure if this is the same problem you're having, mind..
Al.
Al.
I have to do the exact same thing, apps that are supposed to update have to be cancelled and done manually.
