Root Maps battery usage
ben1122a
running CM7 Starship rom with b_random kernel. also using smart ram booster. A few weeks ago, my battery screen started looking like this,
Any reason why? Any way to fix it?
Do you have BetterBatteryMonitor? It will show any waklocks that will give us a clue.
update: the problem seems to be fixed, for now. The only forseeable solution I can see is that I was using ram manager pro and go task manager ex. I then installed ram booster and uninstalled ram manager and go task manager, and the problem seemed to go away, from what I can tell. Now the only 4 on the battery screen are cell standby, phone idle, wifi, and display.
