Root Market 2.2.6 Install Issues + Fix
carassius
I was having problems doing a manual install of the new market app v. 2.2.6. I first was unable to install, then when I was able to get it, it was nothing but FC and was unusable.
Apparently this isn't a problem with all ROM's as most running UD 2.4 don't seem to have problems but I am running charity 11 and others have reported problems running sapphire among other ROM's.
Anyway, I found a solution elsewhere which worked perfectly for me.
Latest version of Market... Vending.APK v2.2.6 - Droid Forum - Verizon Droid & the Motorola Droid Forum
Link on first post to be installed through clockwork.
Also, an inverted market (darkside.zip) can be found here:
Who is going to...[Re-Revisited]-Vending.apk - Droid Forum - Verizon Droid & the Motorola Droid Forum
Installed through clockwork also.
I installed darkside version. Looks great and no FC or other problems (yet).
As usual, make backups before doing anything!
I was able to get the dark market to work but I cant get trublue_Vending_APK.zip to work. I'm putting it in the root of my SD card and then trying to flash it using clockworkmod but it never works. Any idea on what to do?
