Help Market download issue..
squadx
I have searched around to try and find information on this and unless i'm searching the wrong terms (of which i usually have no problems) I can't find anything regarding a fix.
Anything I try download shows up briefly in the notification bar, then disappears right away..
So it would be like this, go to Market > find an app > click FREE > then INSTALL > it shows up in notification bar that it has started, then just disappears... it never installs, never shows me an error..
What I've tried so far...
1. obviously have tried to reboot (more than once)
2. tried clearing cache on market
3. tried using WIFI
4. tried with 4g on and off.. not sure where else to turn for fixing this...
(sorry didnt have JS enabled at first, so the paragraph was all a run on..
Your thread will be moved to the Support forum. I'd had similar problems and it was a Google sync issue. Try removing your gmail / youtube / whatever google account and adding it back. If that doesn't work, create a gmail acct (seriously, I know weird right?) and see if that works.
