Help Market Download Problem
Russell Ng
Android Expert
I always had some minor issues with updates for apps from the market. Sometimes when I click on update, it goes to the white download screen and stays there. Usually if I come back later, it is fine.
But lately, it seems to be happening a lot. Anyone seeing the same problem? Or is it because they are migrating to the new Market, so having problem with the server? The other work around is to go to the market using a browser and download from there. At least that still works.
Just seeing if anyone getting the same issue. Thanks
:D
i had this issue but i went into applications then unistalled updates of the market.apk and it worked fine afterwards
Won't that mean you are using the previous version of market, and the next time you log on, doesn't it request that you update again?
Hi
I have just installed latest market update (3.3.11) and it seemed to fix problem - loads much faster and downloaded all updates which I could not before update.
Boothy
