No, its just you (or well, your phone anyway).
Took me 2.5 hours for one purchased app to download, but usually it's lightning quick. Might just be your coverage at the time.
my downloads are very fast but i do remember back when i first purchased it the downloads did take a little while to even show up. leading me to believe it was not connection speed but the problem did eventually go away
I notice problems downloading apps over wifi. Some days they never start on the first try, and other days they download immediately. Though downloading them over 3G always works. But its slower if I don't have a strong data signal. Its really bizarre that it can tell the difference somehow.serious? i've noticed it from day one. from factory v2.1
now that you mention it, i always d/l with wi-fi
