Help market,gmail,gtalk prob
jungtaee
Hi
I have HTC incredible 2
My market, gtalk, and gmail doesn't work...
For the market its stuck on loading screen and then it closes
Gtalk has an error
Gmail has a same error as market.
Help?
Thanks
Hi
Gtalk has an error
Help?
Thanks
Hello,
Do u have a working internet connection?
Pls check in settings->wireless & networks-> check whether the mobile network is connected to internet.
Do u see a symbol like "E" or ''H" on the status bar??
It could also be your gmail account not set up correctly...if you have more then 1 account make sure you are using the correct account!!
Still doesn't work
Try reset as below:
Google Account Reset
Menu>Settings>Applications>Manage Applications>Google Apps> "Clear data">OK
This will delete the Google account details on your mobile.
NB If changing to a new Google Account you may want to transfer contacts/calendar/apps...etc, which were associated with your old Account to your new one?
To enter new details Menu Settings>Data Synchronization>Google and you'll be prompted with the set up dialogue. Enter your new account details. Hope this helps.
hi I have a LG OPTIMUS BLACK with android 2.2 and I have a serious problem with my gtalk app :mad::mad: !!! when I receive a message, that message is -1 hour that the actual hour on my phone and all the message I receive are placed up and the messages I send are placed down and I have to scroll all the time to see the new received messages !!! anyone knows how to fix this ???
Thanks :D
