Market HELP!!!!
Hi i have the lg ally running velocity 1.1 and it runs great but everytime i clear the data and all that i go into the app market 1 time and download one thing and it downloads. Then when that is done i go back to look for more apps i click on it and it opens up really fast and says something about an error idk i think it forcecloses but it is getting annoying!! Can someone please help!!!!:)
----Thanks that was the exact problem!!!!!!!!! :):):):)
I had the same problem after the market updated on me. If you havent done so yet there are updates that will fix this.
Go to your Velocity Toolkit. Choose Terminal emulator. Type velocity and press enter. Once it connects you should get a menu with 4 options. Press 4 for Script Options and then press enter. Then press 1 for update scripts and press enter.
Once these updates run I think you reboot (cant remember this part exactly)
After that the new market should work great!
