Help Market not working properly?
Has anyone else noticed that when you click the update button under my apps, that nothing happens? You have to go to each individual app and update it from there.. Does anyone know of a fix? Thanks!
Off to the right of where it says update you should see Update and a number (the number of apps with an update) tap that it should start updating all.
Works fine for me every time. The only ones that won't update that way are ones the seem to require a manual update so then I have to do that app(s) individually
