Help market place
I bought an. Incrediable 2 a couple months ago and all of a sudden I cannot get on to the market. I click on it and all it does is bring a white screen up then it goes away back to my main screen. I have tried restarting and turning off the phone but nothing fixes it?
Try going to settings>applications>manage applications>market and click on "force stop" then click on "clear data" and see if that helps.
When ever click on the Market, it now asks me for a google login.. I can't access the Market anymore.. This started after the latest OTA..
Anyone else seeing this?
Check to verify that you have a Google account on the phone. If you do, clear the cache and data for the market.
If that still doesn't work, let us know.
Kratos
I do have a google account. I cleared the cache and data and it worked.. thanks a bunch..
Appreciate all the replies/help :-)
Lucky.. very lucky. After trying ALL the things people suggested for this problem (which apparently is really common) - the only thing that worked was a factory reset on the phone, loosing all the layouts and info on the phone. Luckily my phone book was backed up. PITA. If it happens again (this is the first week of owership) it's getting exchanged for an iPhone (have a month from purchase to do this..)
Yep, a couple months ago my market would not launch. A Factory Reset is the only thing that helped.
I really like this phone but the buggy software is starting to annoy me.
