Root market question after root
Ageguy
Member
i have looked around here and cant seem to find an answer. i bought the adw launcher ex but now have decided to try and root. if i bought apps from the market and delete them do i have to buy them again? i just want to know in case i decide to unroot and go back to stock. thanks in advance for your help.
Once you buy apps they are attached to your Google account, so you only have to ever buy them once.
Will all of your purchased apps run on a rooted X? Are there things that will not run? Just checking before I root mine.
If you root your phone it doesnt change the way anything performs. All apps still work but now you have alot more apps to choose from, and alot more options. You should definatly root via z4root. Its easy and it is easy to unroot if you have to send your phone back for any warrenty work. Your golden
