Root Market_Applications_Games _Enabler
Lks Lks
Now you can enable different country's Google play store apps and games in your country
you can download apps games.
Note: Paid version will be always paid.
Note: Application need superuser permission.
Download link below...
http://db.tt/M1hnPPlJ
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
These both apps are already free in market.its not paid version!!!!
How it works, you need some simple steps to enable non country market apps,
download my zip and extract both files from zip,now install both files,first launch market enabler save current settings first than select "settings list" here you see some country operator codes example [US]Verizon press on until popup (fake this provider now) (set for fakeOnBoot) just click on (fake this provider now) that's it. For"set custom" you need another app market enabler codes in this app you will find more country codes just click on code near country flag it will popup "copied on clipboard" now go back to market enabler/setcustom [Remove operator code] and paste new country code than click [set to this values ] now go to Google play you will find difference..;)
....To go back to your original operator just click to restore settings....
