Help MarketEnabler doesn't enable?
Andronix, is it working for you? Before MarketEnabler used to get stuck every now and then. The remedy was to reboot. But now it doesn't work at all (that is, no paid apps are shown in the Market even though ME does its thing without getting stuck and shows "Done and all set" toast). Reboot doesn't help.
With the latest MarketEnabler version you don't need to reboot. Actually, if you reboot, you'll lose the changes done by MarketEnabler.
So, like Andronix said, try clearing Market cache.
OK. Thanks for the feedback. Good to see it's not a Market/ME issue (like I first thought). I'll try what you've suggested.
