Is it possible to hook the DX up to an external mass storage device? Or is the whole USB thing one way?[/QUOTE
I wil answer you question with a question. Can you hook two flash drives together or two hard drives?
No you can't.
No you can't.
Liiiiiieeeeeessssss!!!! Its called RAID (For hard drives at least).
The Droid X does have the ability to communicate through a dedicated IO port to a micro SD CARD. So, considering this phone is more like a PC than a relatively mindless hard drive, I'm not sure what your point was. It clearly has some ability to access external memory.I wil answer you question with a question. Can you hook two flash drives together or two hard drives?
No you can't.
