rancequest
Title says it all, is it possible to use regular Mass Storage on this phone instead of MTP? MTP sucks.
There is an app called SG USB Mass Storage Enabler that will work if you've got root access.
It will only show the external sd card though, not the internal storage.
Honestly I have no idea. It didn't do that when I use it! Is your sd card installed and mounted?Thanks for the reply.
However, I tried this application and get this:
Any ideas?![]()
Any ideas?![]()
toggle usb debugging
exactly, turn it offIt was already enabled.
