Help Mass storage mode
technomad
In the preference there is an option to choose Mass storage only, for some reason even with this checked I have to tap twice on my mobile screen to activate mass storage mode. Surely if you've chosen mass storage mode only then simply attaching the phone to your computer's USB port should activate mass storage mode and your phone's internal and external memory cards should just show up on your computer.
I think this isn't a bug but LG's doing, which is pretty stupid and I agree with you, if you've chosen it in the options then it should be pretty obvious that you want it in mass storage mode straight away, maybe this will be another feature that is in or should be included in one of the custom ROM's being made at the moment.
yeah, I guess it does...I'm so used to having rooted phones that I didn't think about that. But it does work very well.
mm0
