Help massive vivid problem
man2112
Hey all,
I just installed a new digitzer on my Vivid. Everything went fine, and nothing broke as I was taking apart the phone, or putting it back together.
Now that the phone is back together, however, it is having some problems.
First off, When I try to power the phone on, it vibrates like usual, but then doesn't display anything. The phone then proceeds to enter in to a bootloop and keeps vibrating every couple moments. When plugged in to the computer, the orange light comes on for a few seconds, then turns off. Windows will not recognize the phone. All the while, the screen is completely black, and none of the lights come on for the buttons either.
The phone was working fine before replacing broken digitizer.
The phone is NOT rooted, nor has it ever been. I am running stock ICS.
have tried entering Hboot with no avail.
Any advice?
Thank you!
