Help Max read/write microSD speed supported ?
cdl
What is the maximum read/write microSD speed supported by the Milestone? I couldn't find information on this anywhere.
I am not sure if it's worth spending the extra money for a class 6 (8MB/sec) 16 GB micro SD card vs a class 2 (2MB/sec), as I'm not sure the Milestone will support it.
Thoughts?
It will definitely support class 6. If you buy class 2 you will suffer from slow speeds when transerring anything from the PC o the card, not recommended.
