G Ghost Matter Guest Jul 30, 2011 #1 I've heard info on this but I'm not exactly sure. What's the max SD card size for S2? Does it support SD HC/XC?
icedtea Android Enthusiast Jul 30, 2011 #2 Ghost Matter said: I've heard info on this but I'm not exactly sure. What's the max SD card size for S2? Does it support SD HC/XC? Click to expand... i believe the unit's slot is suited for micro SD type only. . HTH
M Magicgfx Newbie Jul 30, 2011 #3 From all of the reviews I have heard, it seems to allow for up to 32GB of additional micro SD memory.
G Ghost Matter Guest Jul 30, 2011 #4 Thanks. It's what found on some websites. Seems right. Write here if there's any contracdicting info.
