May be a dumb question please read
dansdad
Ok I'm going to go on Metro. Are the apps with the lg spirit the same as any other Android? Thanks in advance..Dave
well android is android and for the most part apps available in the play store should all work with your device. lg spirit comes with ICS so you should be fine with apps.
