Maybe getting phone- Are there ICS problems?
cannon11
I'm definetly thinking about getting a used atrix 2 off of ebay in good condition. I like that it has ics but I hear that alot of people started having alot of problems after they updated, is this just a few people or is it like a sure thing that if you update to ics you will have problems? Cause I want my phone to run good and last a long time,
thanks
thanks
I was given an Atrix 2 about two months ago. It came with ICS installed and I am 98% pleased with it. My only issues is data connectivity when leaving WiFi, and that I am unable to create a WiFi Hotspot under it's current config (see "2 issues w/Atrix 2" topic). Otherwise, it is fast, reliable and easy to use.
Randall
I bought a Motorola atrix 2 with ICS 3 months ago, nothing so far except theres a problem were the message icon looks the same like it was never updated.. other than that it seems fine to me.
