So some of you may know I'm now running mik froyo with an updated radio and prl.
I had that problem with random restarts that culminated in my phone crapping out and losing everything but use of the phone and texting.
So I wiped everything a dozen times. Installed a stock rooted rom and stared at it for 5 minutes and then installed mik froyo. As I was syncing it with google it randomly restarted. This was before the prl, and radio update. It also happened while installing via appbrain. I was installing a lot of apps at once. It seemed the easiest way to do it without using ti backup.
Then I got to almost where I'd like it to be. Everything's in there just not necessarily in the right place. I was using the internet and it happened again. This is when it happens 90% of the time. I think it happens if I'm using the internet or cpu intensive app and the craigs notifca kicks on to update. The phone goes off. restart loop. battery pull.
So can I fix this with setcpu or similar app? What settings should I use with mik froyo?
Thanks.
Thanks.
