maybe upgrading to rezound help?
danibug23
well i do love my incredible 2 very much (had an iphone and missed it so much had to come back to the incredible :) ) but since i have really bad vision and i have some of smallest hand but for some reason my typing on it is not the best on it. has anybody had the incredible and upgrading or upgradeed to the rezound? im thinking since the screen is clearer and bigger it might help me. can someone give me imputs on this please ?
My friend just upgraded to the Rezound (though not from the Inc2), and I have played with it some. The screen is bigger, but not dramatically so. Nowhere near the difference of, say, an iPhone to the Inc2.
EDIT: Just did a side-by-side comparison using the NY Times mobile site as a comparison. I actually found the Inc2 slightly easier to read, as the text was actually slightly larger (same settings, both set to Normal font size). I noticed no added clarity with the higher resolution screen on the Rezound.
Bottom line is I do not think that upgrading would help you out with your particular issue.
I haven't played with the Rezound, and someone more knowledgeable can correct me if I'm wrong, but I think that the fonts will actually appear to be smaller on some of the newer phones with higher resolution screens - even though the screen is bigger.
I'm wondering if Ice Cream Sandwich will finally allow native font size adjustment for android. That will be great, if true.
