MCPE Compatibility
Skythe
I'm thinking about getting the Motion, but before I do does MCPE work at all? (Can it install, play smoothly, etc.) On the wiki it says the phone isn't compatible, but I'm just making sure. Thanks!
Edit: And another question, between the Motion and the Premia which one in your opinion is better, with reasoning? Need to decide in 8 days :/
Considering the specs of the motion i'm pretty sure it will work. I have this phone and i play some big games on it with no lag or skipping at all. i haven't tried MCPE on it though. This Phone is a great i have no problems with it.
MCPE works perfectly fine on the phone. I've played it numerous times without any problems. The motion has more internal memory than the Premia.
