Root MD5 mismatch
sellersj27
So I decided to try Quatrimus today....wiped everything just as i did when installing cm7. I was unable to download anything on quatrimus, so I went back to cm7 0502. Now, all of my nandroids show an md5 mismatch. I assume that this was from the system format. Is there anyway to fix this?
Md5 mismatch means what you were trying to flash or restore has become corrupt. Try downloading fresh and try again
Quatrimus cm9 is coming along nicely. I know I'm impressed it feels faster then iho a lot of the time. Anyway glad you figured it out. I'd make a new backup ASAP tho
I made another nandroid.... what can I compare it's md5 to?
Did you happen to change the name of the android? I think that would also cause a mismatch... I'm not sure how to know what the Md5 of a backup should be... Apparently the recovery knows tho
