Help Media beep, every 5 seconds, will not stop
kender
Okay, it will stop under 2 conditions that I have found
First, I mute Media volume, it will stop the beeping from being audible, but it also stops all "media" sounds from happening
Second, I open a google voice search box, as long as the search is actively open in the foreground (not running in the background) the beeping will stop, but close it, or open another app and it will start beeping again
The problem started today when battery was low power (close to dead) and I missed a call.
The problem occurs when charging, not charging, on a call, not on a call, with random apps open (except the voice search so far)
From googling the problem I found several things to try
  • I have pulled battery and reinserted
  • I have powered down, did "Home + Vol Up + Power" and cleared cache
  • I have pulled battery while plugged into charger then reinserted
I would rather not do a system restore - I live in a low connection area so would have to drive for a 4G signal to get the phone to activate again
Does anyone have any suggestions, please and thank you?
it was the Open Mic app, there was an update to google search that went along with the update to open mic, some reason my phone didn't realize it needed to update Open Mic and didn't even show as installed in "my apps", so once I updated the new Open Mic it stopped causing issues
