Hi, got my new media link yesterday. Setup and config was very easy, but when i started the Netflix app, and a movie the picture and sound just stuttered on my television. On my phone it was smooth. Any of you know how i can fix this?
Where / how can I find the HTC Media Link HD's wifi mac address?
My roommate has the wifi router in our home setup in such a fashion that we have to manually put in the mac address of the device we wish to connect to the home network.
Pain in my ass he is.
*ALSO*
What is the latest sw/firware version for the HTC ML HD? I'm on 2.99.103.11
For what it's worth I'm on a HTC Droid DNA. Not an evo, like most of you.
Also when the splash screen for media link pops up on your hdtv, at the bottom of the screen it will show its mac address right before it connects to the home network. I can't get my HTC media link working it keeps saying firmware update I try to update and there is no update ....someone please help me... Asap
THANKS EarlyMon.Yes.
The Media Link has been around a while, you want the Media Link HD.
Are there instructions for how to do this?If your TV is equipped with DLNA (many are) you can view some of your content from your phone without additional hardware.
I finally fixed it by going into the Recovery menu and Wiping The Cache.
try to config wifi manuly when saving it says "internal error" cant connect to my wifi
Yes, my old Evo could sync up with no problems at all. When I tried syncing the new phone, it said it wanted a PIN which I didn't have, so I just factory reset it and reconfigured it. But even with all that, the Media Link screen never shows up on the TV.were you able to sync up the media link to your old evo before you broke it?
do another reset on the media link. let it connect to your wireless network. it its not connecting to your network and you are using security, chage it to wep temporarily so you can get better odds of the media link connecting to the network.
You will need the medi link passcode to gain entry into it to change its settings later on, and that code has been posted in this thread.
use a high speed hdmi cable. the one you have could be damaged.
change the resolution to 720p or 480.
main question is dos the media link connect to your wireless network with no issues? if it does, make sure the evo is seeing it in the media link tab.
and see. It works on my TV at home. Synced up with no problem.ok, sounds like something is wrong with your media link adapter, the hdmi cable or both.
at the very least if you plug up the media link, it will go through its boot up and the htc splash screen will come on, then you see the finger swipe. this happens even if the media link is not connected to the wireless network.
if you have been able to move the media link to another display and you see the resolution error message on the other display, try a different HDMI or one again reset the media link.
if possible, try a THIRD display (!!)and see.
what I am gathering from your post is the phone is fine and connects fine this is an issue with the adapter. after a factory reset if the adapter still refuses to display, it could be defective.
its difficult to diagnose over the internet. to me i thought you were having issues with any display you connect this to, but now you cleared it up for me and i see its just the display at the job.
that changes things. since it works at home and not at the job, then its the display at the job. check the resolution settings on that particular display and adjust as needed.
does any other people use this display at the job? could be any number of reasons why the job display is not working.
if you still have issues, then check the website of that particular display manufacturer.
