Help Media player?
Foxspeed
Two recent media apps that I had don't work too good now with 4.3 update so can anyone recommend a good one to use?
Thanks.
A lot will depend on what you are wanting out of your music player. For example, I'm using Google's Play Music app, but I realize it may not have the features some people are looking for, but it is perfect for me.
My suggestion would be to send an email to the makers of the apps you have been using, let them know of the problems you are having using their app with 4.3, and ask them when they will have an update out that will be fully compatible with 4.3.
Likely they are already working on an update to fix things. If so, you won't need to find a new app, unless they have a very slow development cycle.
You looking for a media player . Try JETaudio lite or the jetaudioplus . This thing rocks . You have eq to set the sounds you want and the darn thing even have crossfade yes it do and if you dont know what crossfade is . Well when the end of a song comes along it mixes that with the next song . Try it out very nice and ui is so lovely .
Thanks for the replies. I was meaning more for watching vidoes/streaming etc as I founf MX Player didn't work anymore and Dice Player seemed to be 'choppy' when watching.
For music I use PowerAmp.
Thanks.
O ok i got you i used mx and got no complaints .but you can also go with REALPLAYER. This thing rocks also and it scans show pictures ,videos and music.
When I try to watch video with mx player it stutters crazy bad. Idk how to fix it, any help? I thought it was my connection but if I use the stock video player things play just fine...
I forgot its a setting in one either java or ???? I forget it ...just check the hardware accelerated video player, and multicore decoding, if your device supports that. Both should provide roomy playback,eliminating processor slowdowns
Thanks I got it working, for now at least. Now if I can get it to play in higher def, video quality isn't the best but hey...
Thats good glad to see you got it working for clear video make sure you have the ARMv7 processor. Selected if you dont see it and cant select it just go to the playstore and download this apk
io.vov.vitamio.apk.
Select the one that is arm7
io.vov.vitamio.apk.
ok so i went to playstore and download armv7 neon, as it was the one mx said i should get in settings, but idk if videos are any clearer....
