If you have no sound how do you know it's playing your audio media too fast? So I'm going to assume you mean videos when you say 'all media'. What app are you using to play your media on? What format is your media in?
I have no problems playing any media (audio included). For videos I use Rockplayer which seems to play back most formats. For audio I use the stock music app that comes with the DHD.
Sorry i should have clarified, i can see the counter moves too quick, like at 4 x the speed.
And in the video, well you can see its all moving too fast.
To be more specific it skips in chuncks of 3-6 or so seconds at a time.
Using the standard App for both music and video.
Format for video is .avi which has not been a problem before.
Format for music is .mp3 no probs before either.
Pep
Thanks Sombre for your help.
Turns out it was having an issue with my BT head set, it never occured to me cause at the time the BT on the phone was turned off.
Turned off headset rebooted phone and all good now.
Pep
