hi
this is the problem in my Galaxy S2 Gingerbread 2.3.3
I have 16 GB of SD it was before every time I add mp3 in my music file on the SD it appears in music player and also my video it appears in Gallery
but after sometime it doesn't adding the files with Samsung Kies or by normal connecting the usb it will be the same problem
then I perform clear data on media storage and music and restart my Galaxy S2 and sometimes it works again but it's mix my contact raining tons
and after some copy times it returns to the same problem
when I disconnect the mobile from PC it gives
1-media scanning running
2-media scanning complete
but nothing new is add to the files
and if I go to My file App the music and videos are add to the SD
and If I use other Media player Like MX Player I only need to press video scan and the new files are shown
so what cause this problem ?
I tried installing startup manager but even so disable media storage and adding other manual scanning didn't help
so the problem is the media scanner doesn't recognize the files are add after sometime
my Galaxy S2 info
android version 2.3.3
baseband version I9100xxkg1
Karnel version 2.6.35.7-I9100jpkg5-cl428948 root@dell137 #2
build number gingerbread.jpkg5
flash and rooted from this files
my Galaxy S2 info
please help because this is driving me crazyCF-Root-SGS2_JP_XSG_KG2-v4.1-CWM4
mediafire
mediafire
JPKG5 Stock Kernel: Multiupload.com - upload your files to multiple file hosting sites!
Password: intratech@XDA
CF-Root-SGS2_JP_XSG_KG2-v4.1-CWM4.tar
