Help Media using 23% battery for no reason?
dallows
So this is just a recent occurance. I noticed that in the mornings after I have my phone charging all night the "Media" (how it's listed in battery use) has already taken up 23% of the battery power/life/usage whatever.
It only shows running for a few minutes and actually as I type this it's going up - even though no media app is running that I can see.
I started noticing my battery dying quicker than usual even though my usage patterns haven't changed.
Any ideas as to what is going? Thanks.
It's still doing it. I took the phone out of my pocket and it was hot, cpu temp at 116F Under Media it has listed:
Download Manager
DRM Protected Content Storage
Camera
Media Storage
I checked my services once before and saw the DownloadService was running. So I killed it and seemed to help.
Anyone have a clue as to what's happening? Thanks.
I can't say that I do. I can only ask a couple of questions.
When did you get your last OTA update?
Have you tried a battery pull? How about a factory reset?
I had some annoying battery drain issues and wifi issues as soon as I got the FRG01B update, and a little of the battery issues tapered off after a couple of reboots.
The wifi problem I only managed to solve by rooting my phone.
Perhaps someone more knowledgeable than I will chime in here...
cheers
FroYo has JIT enabled, as well as having a stock overclocked kernel to around 800 MHz - if your phone ran warm before it is going to run warmer now.
If your usage patterns are identical to before then you can expect your battery to be used faster - but it shouldn't be very much faster.
Muab is correct - perform a factory data reset and see how that goes for you.
Thanks for the responses but I left out some details, so I apologize for that.
I'm currently running Bugless Beast v1.1 which is Android 2.1. I have been running this config for months flawlessly. It's only recently this changed. I uninstalled any recent apps I downloaded that pertained to media but no luck.
