Help MediaMonkey sync?
S
SoFLO
Guest
I'm moving away from iTunes and decided to go with MediaMonkey. This may be a newb question but how do I sync my EVO with MM? I also have some music already on my EVO from DoubleTwist.
Just did this today and it works great. There's an issue with MM copying files and not preserving the directories. It tries to copy everything to the root folder. To fix this follow these instructions.
Beyond that you click on the down arrow next to the little portable device icon on the top and configure how you want everything to be synced. Once you get it set up correctly you can just right click and sync a track.
In my opinion MediaMonkey is the best music management software and hands down the best at large libraries.
+1 for MediaMonkey being the best music management/player software available. And thanks for the info hayj, I may actually use it to copy tunes to my EVO now.
