Memory Card !
S
SweetyAndrN00B
Guest
Which memory card I buy for Micromax A75 ?
i selected few (all Class 6 Cards) 8 Gb & 16 Gb :D
Suggest me ..about Class and memory size for A75 :)
link or this link
So do i need to add more Class for A75 and if i use 16 Gb than it'll perform okay or it ';;ll eat my phone's speed ?:bebored:
1st thing....
are you going to buy it at 10pm tonight?? urgent??? btw if online shopping, I guess same thing :p
2nd...
the class is simply the read/write speed of the card. Class 10 are usually needed in continuous shots for dslr's. Btw for android phones with 3M camera, class 4 or 6 is sufficient.
Regarding the size, am using a 8gb class 6, never felt a hang though. 16gb wont be a problem, but are you sure you need so much?? A75 is expandable to 32gb,.....I guess it should be stable for atlease 8!! :p
Hope it helped :)
btw, the thanks button is there for a reason ;)
Thanks for your Reply..
i know per kya 16 gb add kerne pe ye bilkul sahi performenc dega ya 8 gb he theek hai ?
8,16,32
All would work same.
Now it depends on u how u want to use your phone as.
If u r movie or music addicted, go for 16 or 32.
If as a normal use,
Even 8 would b enough.
performance baad mein socho.....quantity dekho......do u really need a 16, or are u ok with 8?? once that is done, select any of them acc. to ur need ;) :D
hahaha apna goal to torrents se stuff download kerne ka hai..wo bhe khoob dher sa :D wo bhi padosi k WiFi se ..bada maza aane wala hai heheheh :laugh::stupido2:
8,16,32
If as a normal use,
i have seen many ppls using 8 Gb in there phone but i don't want my phone to lok like Ordinary phone so will go with 16 GB :D
link
absolutely....padosi ki wifi ya college ka wifi free mein use karne ka alag hi maja hain....2 saal se main kar raha hun....;) But since I am the landlords son, kuch bhi bolte nahi :p lo karlo baat :D :p
ab mai 16 GB he loongi :p hna nai to :D
btw, the thanks button is waiting :p:D
If not already bought and u r planning to install lots of apps/games using Link2sd then I would suggest to go for Class 6 or Class 10 cards for any size 8,16,32...
Though it is not necessary.(I am using Class 4,8gb...lots of apps on 2nd partition least lag so far)
Can someone advise me how to mount ext2 partition done using CWM recovery. I created the partition of 1gb with swap size of 512... but the link2sd doesnt mount the partition.
Thanks in advance
Thanks in advance
A75 does not support ext2 out of box.it will support FAT partition only.to get ext2 support u need to place ext2.ko file in /system/lib/modules.then only link2sd can mount ext2 formatted 2nd partition.I m on mobile so cant give link to ext2.ko but u will surely find it in General Discussion thread,I have posted there link to ext2.ko.if anymore query,sure post here,we all help u out..
