ramsbottom
Ok
I have my new S11 and I am confused about the memory. It has 12gb internal SD (Mass USB), and no external. I believe that the Samsung thinks that the internal memory is an internal SD card(Mass USB) and that when I fit an SD card it will be seen as an external SD card - right? So I have a 12GB + 32 GB SD phone
My confusion is with the 2GB internal memory as well. I have installed loads of apps and these seem to be going in to the 2GB internal and I dont get the option of installing them on the 16GB Internal SD(Mass USB). Even is I use the apps2sd app, which I thought I wouldn't have to use as this memory is internal.
So currently I have 12GB internal SD with nothing on it
I would like to have the apps installed on the internal SD storage (Mass USB), and music and videos on an external SD Card. Can this be done? help im confused
Bloody unbelievable phone though, makes my Iphone 3GS look carp
