Help memory issues with go launcher ex?
i know the issue of the restarting phone has been discussed but i wanna know if having go launcher installed and in use makes it much worse. I have to restart like 2 times a day because my RAM just keeps going down and down and down until it restarts. I just like having the folders and calender widget in go launcher. are there apps that can suppliment these? if so what are they?
go launcher ex
go contacts
go locker
go sms pro
+ themes to go with them, no shutdown or reboot issues here
I have too GoLauncherEx, GoContacts, GoSMSPro, etc, and a lot of apps. My ZTE Warp works very very stable, no FCs, no reboots, all OK and fast.:D
you might want to rest your device, because that shouldn't be an issue.
What do you call "resetting?" Cuz I have the same problem, I think that there is some kind of combo with the apps that makes the phone mess up, I have factory reset my phone at least 20 times now just to find out what the combo is but I hav had no luck. Maybe it is just how many apps you have, rite now I have almost 400 apps and i need to restart my phone allot, and it constantly freezes and reboots almost 10 or 15 times at a clip right in a row.. But I have noticed it only does this when I have got to a certin amount of apps loaded back in. I have hundreds of dollars already invested in the software for this phone just from the android market. I love to have apps that make my phone do stuff. and I am in no way complaining about this cuz I will find the app that is messing with me sooner or latter. as soon as I do I will post my findings. but from what I can tell rite now it is just how many apps you have installed into memory and ruining as to how many restarts you have. I don't think that the warp likes to have allot of things loaded into its mem.
Should be an app making phone unstable.
If you have phone rooted you can use Titanium Backup to save all apps, then uninstall all, just left the few most importants, if you do not have problems in a day you know is an app, so you can restore an small group to test another day...
I have 366 apps but only issue I have is music auto starting sometimes.
Yes, I am up to 400 now and my warp is rooted, I have done just the very thing you said. I have all my apps backed up on the card and onto my laptop., I have been trying to find which combo of apps is giving me trouble. When I factory reset the phone and then re-root it, and just load in what are important apps to me, the phone runs great no problems, but when I get to a certain amount of apps it starts to act up again. I think this is a problem for allot of peeps but they just don't know it yet. So I am working on tracking down the misbehaving apps and then we will know whats messing things up. well a little bit of info may go a long way for some peeps, hopefully, I can help someone else out with this info when I'm done. We will see how it goes.
Found out anything new yet?
It seem that no matter What I put in it still wants to mess up just on how many I put in... As soon as the memory starts to got up from apps being loaded into memory it wants to start locking up freezing in any app and then just restarting, once it restarts it will run fine for a little bit then it will start acting up again. and it does not matter what I am doing or what app i am in it does the same thing all the time. this leads me to be-leave that it is a memory issue with the warp.
Done all that, with no results making any difference.
It's a flaw in the design of the phone.
I am gonna try one last thing before I decide to factory reset the warp. I am Going to freeze all my apps and turn all the system apps that came with the phone into user apps with titanium backup, then I am gonna turn the other apps that take the place of the system apps into system apps. so I only have go launcher ex pro running in memory and not both the old system app Launcher that came with the warp and my new take it's place app, in memory. Then I will see if this gives me some more ram back and I will also see if it lets my texts come through as soon as I get them. ewwww I hate it when I get a text from my son, after he comes home from work, when I should have got it like an hour after he got to work.....That really upsets me..and I know it is only a darn memory thing, at least I think it is....we will see what happens....I will let you all know...
