M Mike777 Well-Known Member Sep 24, 2011 #1 Hi all My menu button has stopped working.... If I hold it down longer the keyboard comes up..... Any ideas on a fix Many thsnks Mike
M Mike777 Well-Known Member Sep 25, 2011 #3 SUroot said: Rooted or not? Click to expand... Not rooted Thanks
SUroot Extreme Android User Sep 25, 2011 #4 All you can really do then is, factory reset and hope its software related. If you Google visionary+ you can temp root and use titanium backup to back everything up. Then temp root to restore
