Help Merging Contacts?
I just moved from the Droid Razr Maxx to the Note 3... this is a potent new device. I have one MAJOR problem, when I sync my contacts (using 2010 MS Outlook & an Exchange Server)... contacts with similar names are combined into ONE contact. This also occurred on the MAXX, but I could go into the menu and edit/divide them. How do I do that on the Note 3 (Android 4.3?). It is infuriating... I may have two contact with same last name and all contact info listed under ONE name while the other is not even listed! All my contacts on Outlook are unaffected.
HELP!
Thank you.
