Root [Merit] [MOD] Custom CPU Governing without Custom ROM or APP [SCRIPT]
stayboogy
Android Expert
[I am not responsible for any errors, malfunctions, overheating, etc that you may experience from running your cpu frequency too high or too low--these are released purely for modding sake. They do work, use at your own risk.]
requirements:
a) init.d scripting function
http://androidforums.com/merit-all-...dd-init-d-scripting-function-your-device.html
b) a root file explorer
downloads:
***download files using a pc--i do not support / suggest using your phone***
init.qcom.post_boot.sh
cpumax
cpu frequency will never run less than 600000 (cpu max)
cpuoptimal
cpu frequency will run between 600000 (cpu max) and 480000
cpumids
cpu frequency will run between 480000 and 245760
cpumin
cpu will run between 245760 and 122880 (cpu min)
cpuorig
this sets it back to stock governing--between 600000 (cpu max) and 245760
DIRECTIONS
1) download the init.qcom.post_boot.sh from above and copy to your /system/etc/ directory and overwrite the one that is there already
2) download the cpu script that you want to use from above and copy to your /system/etc/init.d/ directory and give it permissions 777
3)
reboot your phone
[should you wish to return to stock, copy the cpuorig script to your /system/etc/init.d directory and give it permissions 777, and reboot the phone]
THANK ME IF YOU ENJOY THIS MOD
IF YOU REPOST THIS SOMEWHERE ELSE LINK BACK TO THIS ORIGINAL THREAD (only applies to this mod, not the rest) AND GIVE ME CREDIT]
