Root [Merit] ZTE Merit Touchscreen Bricked after *983*29873283# code
micallan_17
as the title says, I was experimenting with some of the *983*------# codes and I tried this one *983*29873283# and said something about firmware update and to not touch the screen (things went sour after that) I got scared and took out the battery and when it rebooted, the screen wasn't working anymore, I no that code did something to the firmware and that's why the screen isn't responding no matter what I do. I do warn anybody that don't try this code cause it might brick your merit/avail. I came here to ask for help and see if anybody has had this issue and if there is a fix to it. I would greatly appreciate any help. thanks
I dont have it installed, but if its needed to get the phone's screen back to work I can install it, which version is needed?
TouchNav-1.3-ext3.zip
download this file, rename it to "update.zip" and copy to the root of your sdcard
merit.stock.rooted.rar
download this file, unrar it, put it on your sdcard in this file structure
sdcard
-folder named "clockworkmod"
--folder named "backup"
---folder named "merit.stock.rooted"
----all seven files from the rar
power off phone
hold volume up and menu keys, power up the phone while continuing to hold those two keys and wait for stock recovery to boot
install the new recovery by pressing the back key on the second option in the recovery menu (ie. wipe data:factory reset--no it will not wipe anything but it will install the new recovery update.zip)
then choose the reboot system now option, and immediately start holding volume up and menu keys afterward to reboot into the new recovery
once in the new recovery, choose "recovery tools", then choose "restore", then choose "merit.stock.rooted", then choose "yes" and let it restore
then reboot your phone
you will be completely stock and rooted
PROBLEM SOLVED
well it did bring the phone back to stock but still no response from the screen, am sure it has to do with the base firmware, which of course Tracfone has it locked, is only there was a way to get into FTM mode, that would work wonders
there is a way to get into FTM, but that won't fix your issue.
you have to have stock recovery
then you just hold volume down and power key until FTM loads
***edit***
this apparently doesn't work, but i know that i have gotten into FTM about three times, but i can't remember the button combo to make it load. stock recovery is mandatory for it though, as the images for FTM are in the ramdisk of the stock recovery.img
you shouldn't have been using the blade 2.1 rom update dialer codes in the first place.
but there's surely a way to get your phone working again.
maybe try installing one of my roms and then see if your screen is still not working
also try pushing the reset button for several seconds (take off back cover, little button by camera lens)
do those things, then get back to me
if they don't work, we'll try a few more things
hold the menu button first, then hold the power button, and hold both until the phone boots completely and you see "safe mode" in the bottom left corner--the phone will vibrate after the boot animation if done correctly
see if the touchscreen is working then
thanks for all the help, stayboogy, yup I learned my lesson alright, can you provide your links to your roms, and also instructions on how to get it to FTM mode, am willing to try anything it might be worth the try
do I need to be on the stock rom/stock recovery for this?
it does go into safe mode but nothing still
***edit***
yup I tried that too, and do you have a link to a stock recovery image file?
I headed over at Android Area 51's website and one of the Developers told me its bricked and the only way to fix it is by jtagging it, which he said is expensive.
i don't really agree with this assessment at all,
**real, true bricks are not common with android systems. 80% of the time what people consider to be a brick is nothing more than a problem that beginners can't solve**
but i do have one more suggestion that may just fix your issue. but it will require some work. and sadly i won't have time to help for several days.
essentially i'll have you restore a nandroid of the att avail system, that i've made
then flash an official image.bin that includes a number of things that are not included in any nandroid or update that may just correct your problem.
but i'll have to get the image.bin uploaded first. and that won't be until tomorrow evening some time.
just be patient and don't do anything drastic, unless you purchased the extended warranty (and it's still active)--which if you did and it is, then you need to just return the phone for a new one following the instructions on the warranty card
EDIT--SEE NEXT POST
download this and restore using the same method as before
avail.unrooted.rar
download this, copy to your sdcard, and install it from the custom recovery using the "install a zip" option--this will give you the stock avail recovery, install this after restoring the above nandroid
Avail_stock_recovery_update.zip
download this, unzip it, and put the image.bin in this file structure on your sdcard
P020111107491720801969.zip
sdcard
-(folder named) image
--image.bin
go to settings, about phone, system updates, storage card updates, press ok, and follow the directions
once the phone reboots and the image installs, reboot the phone and see if all is working correctly again
if so,
you will need to install the custom recovery just like you did before, then restore the merit.stock.rooted nandroid just like before to get back to the standard ST/Net10 system image and operation
I will try your method and see what happens it after mid night here so I will it tomorrow and will report back, I myself wont be available for a week so take all the time you need, I appreciate all the help thanks
I don't think we are sub par at all. We are small but we work very hard to help people. We aren't sponsored so it it's money from our own pocket that keeps the site & IRC going. Everything is free to everyone.
I don't think the phone is beyond repair ether. I'm not sure who told him that or if it was even a dev.
I did appreciate the help from the IRC channel over at website I visited, the guy that told that stuff went by user name Phydeux, am sure he is a known developer, weather the information he gave me was accurate or not I still appreciate it.
is there any other way to flash the image.bin on the phone since the screen isn't working I cannot get to the settings, about phone, system updates, storage card updates, I have a feeling we are close guys
hey guys just a quick update, I was doing some research and found something interesting here and since it requires USB debugging I had to flash it with this rom PhydeuxROM-2.1.2-Unified-CWM6.zip since it seems the developer enabled USB debugging by default it was able to connect to my PC and using the above instructions I was able to control the screen from the PC a pic can be found here. the screenshot shows the actual screen I got when I entered the dialer code of which am talking about.
if you were able to control the screen that way, then i'll make a nandroid of the att avail system with debugging active and you can proceed with my method as it will not work with that rom because the system won't pass verification when the image.bin tries to install.
i'll post a link in a bit.
then you can proceed.
