i have a little problem on my ascend 300,buts its annoying me,all my contacts are listed only once in the phone book,but when i go to send a message there listed twice,and i cant find a way to delete one of them,any idea`s please?
I'm thinking that you may have "phone" and "google" contacts both enabled in the contacts configuration menus. Check your sms and "contacts" apps. You can remove the "phone" check mark and reboot to solve that issue, then sync to be sure Google/Gmail contacts are in fact all there, if not, just input them online via computer and then sync, if you want to see it being done.. you can also of course just add them in your device, making sure to designate only "Google/Gmail" or however it's worded in your menu.
