Help Messages stuck loading
dgdave
My wife's resound started not pulling up text threads. She can see the list of threads, but when she chooses one, it sticks on loading. If she gets a text,she's able to go in and see all the messages. I had her clear the cache and the clear data button is greyed out and not clickable. I loaded go SMS and everything works fine.
Any ideas?
She's completely stock ics.
Ah yeah, I've had that. Happens when there are a lot of SMS's in a single thread for the stock app. I usually just delete the thread (there's an option to keep the locked messages). 3rd party apps deal with such large threads better.
This is where I was going with it too, basically you have two choices... try a third-party app like Go SMS Pro (or your SMS app of choice), or stick with the stock message app and clear the troublesome messages out manually and start over by long-pressing the thread (don't open it) and click delete, you should also set a Max Msg per thread, in the message app go to Settings-General and tick "Delete old messages" and set your text and mms message limits, i find a setting of 500/50 is a good balance to use, this will generally prevent the issues you are seeing.
