Root Messaging fix anyone?
I'm running He's CM rom and I can't get messaging to work. I receive messages, but I can't send them at all. The other person doesn't get my messages at all I tried reverting back and installing it again and it still didn't work. Any suggestions?
Depends on what rom you're using. I know how to fix sms.
Alright here's the flashable sms fix.
I haven't tested it yet so tell me if it works or not.
Most likely does work. But anyways this will fix sms for hk's beta 4. I don't know if it will also work on any other roms you're trying to port yourself. But it's worth a try. Just be careful.
I figured this out when I fixed sms on Miui. If you want to know how it's done PM me.
https://www.dropbox.com/s/72nasy4vc5m1bhb/SmsFix.zip
sadly, it doesnt
Go to system/framework. It should be in there. If im wrong someone correct me
thats correct. oh btw if you guys use that rom or any other hk based port with loki you'll get bootloop because it's d firmware based.
if you guys get it fixed let me know i have permission to edit and post mirrors for that rom. i can update it.
well i flashed the .zip and now im stuck on the boot animation but it doesnt look like its restarting the animation just constantly goes on. ill try manually now, and report back in a few.
You'll get the same problem.
Someone PM me I'll tell you what you need to do. I think I have an idea of what's wrong. Too lazy to try again still working on slimbean.
Going to try that last zip after I charge my phone. I stayed up last night trying to get this working replacing the mms.apk and framework.jar, but I don't really have time to try today... I PM you you, TheDemon, you're more knowledgeable than me. Hopefully, you can guide me(us) in the right direction.
I'll just tell you how here.
The reason why sms sends blank texts is because HK used our korean or chinese "twin" device The Optimus LTE2 (It's just a little bigger). The device has a sms text encoding set to Korean or chinese so when you try sending text with english characters it sends blanks. You need a framework.jar from a device running the same rom your using. I typically use another device thats LG. I did that with Miui with a random lg device. And with Paranoid I used PlayfulGods cm10 for our device.
The trick is the framework.jar. Inside you have a file called classes.dex you need to decompile that. So open framework.jar with 7zip, pull out the classes.dex and use this to decompile and recompile the file http://forum.xda-developers.com/showthread.php?t=2163286.
You will need two folders of this tool. I have ROMToolsPCv3 Base, and ROMToolsPCv3 port.
The classes.dex that you're trying to fix should go in port and the one you're taking files from should be in base.
Inside both folders you should have classout>com>android>internal
I replaced internal(port) with the one from playfulgods(base) completely and it fixed paranoid. Same with Miui. So that's why I don't really understand why it didn't work. Try replacing just Telephony with the folder from PG's and maybe textservice.
Do not go crazy and use a random device as base. I used a random htc and bricked my motion or put it in testing mode or something when I didn't know what I was doing. But make sure to back up your modem.
If you still can't get this to work I guess I'll flash HK's beta 4 and try myself.
I've tried, but I'm gonna keep trying.
If you do have the spare time, please do. I think I'm just about ready to give up.
