In past, I did roms for MT4G,Amaze,S2 and worked fine, but the One S is giving me a problems. Normally, I use stock rom, root, deodex, remove some apps then run 99 and worked fine, but this time I have a problem. I am trying to make "clean" rom from JB OTA. I had to decompress the Firmware and get the boot.img out. Then, having Meta, Sytem and boot.img, I zipped back and put in Original Update folder. Proceed with kitchen. After 99 finish, I try to flash it but with error 6. I know that I did the Eddy conversion back. Should I remove the boot.img from output zip as I am S=On?. Since, I have the boot image already, should I flash only the rom (without the boot image)?. Man, This S=On is getting on my nerves.
