Root Metamorph battery themes
ACD168
Android Expert
I made a bunch of MetaMorph battery Themes today so I figured I'd share.
I TAKE NO CREDIT FOR THESE.
I simply took them from different ROMs and made them compatible in a metamorph.
I tested all of these out on Ivan's Official 1.0 O/C ROM and they work fine. So they should work on every ROM.
You Need MetaMorph + R00t for this to work. MetaMorph can be downloaded (Free) on the Market.
This is taken from the Aloysius ROM.
Multiupload.com - upload your files to multiple file hosting sites!
This is the Blue Circle battery add-on for the Fresh2.1 Rom - I just made it work with all ROMs
This is the Blue Cyanogen battery
This is the Green Cyanogen battery
This is the battery from the Fresh 2.1 ROM
This came from the ZenEXP ROM
