Root (Metamorph) Droid X Theme
phillip_viado
It's kind of poorly implemented. You got lazy with the XML so there's tons and tons of pictures and animation sequences that you're supposed to be using, but since you're not... they're just taking up space.
You just took the images and the XML mapping from other themes and recompiled it.
Not cool. If you're going to submit a theme, please put some work into it so that it's not clogging up our phones with dead dependencies.
you dont have to use it. At least he is trying. Thanks to phillip_viado for the theme.
Its good to see people theming but there is a right way and a wrong way. Rework the theme using images that are actually used on our phones and do the XML correctly and you'll have a nice theme.
Such as you did with 'FFFFFF', great theme, very well put together, using it now. :)
Thanks again GRZLA.
