Root MetaMorph (Mods/Themes)
I haven't used Metamorph since my OG Droid, but I did compile a couple tweak packages back then. All it is really doing is replacing images.
Knowing this, I would think that anything would work, unless specifically states not to use for certain Android versions.
I strongly suggest making a nandroid backup before using Metamorph. That way, if it doesn't work properly, you can revert to a stable state.
Kratos
