Root metamorph problem.
AwesomePie85
So I tried to use use metamorph to apply a new status bar. But either it wouldn't change or I would have to turn off my phone because it constantly force closes and makes my phone unusable. I have used metamorphosis to apply a lock screen color change and some other things to match my theme and that worked. The specific theme is named something like 50% (it makes your SB 50% see-through), it says that it was made for the Droid but can work (theoretically) on any 2.3 device. So is it my phone or the theme? Also tried to metamorth battery icons and that didn't work either. Runnng CM7. Has anybody had any problems with this or am I just stupid?
Any help is appreciated :-)
Probably because the Ascend is a MDPI device and higher end phones such as the droid are a HDPI device
