So I'm trying to apply themes and metamorph will take forever (it never completes) when applying each item. Periodicly I get forcloses and waits for Su manager and mm.
If you have rom manager run the command that fixes permissions. After that make sure you flash your rom, then apply the theme files through metamorph. I'm not really sure whats happening, Either you are running out of memory and its crashing your apps or the files you are applying are damaged.
