seems MM is a hit or miss. the battery icons should work just fine since they are still in framework-res.apk
signal, #g 1x, wifi, status bar, BT, alarm ect are all in systemUI.apk which, from what i just read a little bit ago, is not supported by MM yet.
ninjamorph did work for me when i was on the deodexed stock GB for changing out the systemUI.apk so that may be the rout to take if you want to change anything BUT the battery icons. and NinjaMorph, did NOT work for me to change the battery icon.
